01-24-2024
05:46 PM
01-25-2024
10:10 AM
Dunkman
I just got a text message today saying I can't transfer my number over to Public Mobile? But when I set up my account everything went through good. Please help I need to keep my number
01-24-2024 05:53 PM
@Paul871 what message did you get?? did you provided the IMEI instead of old provider's account number? It is safer ilti use account number.
There is a number to call to talk to live support. You can provide them the account number and they can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
01-24-2024 05:51 PM
use this link to see if your number can be ported to PM...
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do
01-24-2024 05:50 PM
You can check if your number can be ported here.
If yes, contact Public Mobile at the link below to inquire on text you received . Next link below.
