Need help retrieving account
Hajiandsara
I need help retrieving account, cannot log into my account and forgot which email I used to activate my account. Can someone help please!!
@Hajiandsara
Did you click on Forgot Email?
hi @Hajiandsara
you still have active service with PM?  you can have PM support to confirm your login.   You can submit  ticket by direct message:
slusagm
if you cannot login, you will have to ask PM to get the account number for you.  Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
