01-24-2024 05:21 PM - last edited on 01-24-2024 08:00 PM by computergeek541
01-24-2024 05:45 PM
Port your "rail "?
What's that @Dylan727382 ?
If you mean move a SIM card to a new device, simply take it out of the prior one and put it in the new one.
You may need to add or remove the outer adapters depending on SIM card slot sizing.
01-24-2024 05:23 PM
Public mobile doesn't deal with emails normally. If you need to contact a support agent you can do so via; https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Also writing the exactly problem you are facing here might help as other members might be able to help you out. 🙂
