07-04-2022
07:47 PM
07-04-2022
08:08 PM
will13am
Could you please unlock my account? The email address on the account is xxxxxxxxx@gmail.com
Edit:. Email redacted by will13am. Please do not post personal information in the public forum.
07-04-2022 07:56 PM
H @Macje Remove the email, this is just a forum and we are customer
you can wait 3 hours and try again.
If you still cannot login, try to reset Password using the Forgot Password there
Last help would be from CS Agent, open ticket with them:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
First type: "Forgot log in information"
Then Click "Contact Us"
Finally Click "Click here to submit a ticket"
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
07-04-2022 07:51 PM
Remove your email from public forum.
Contact agent to unlock your account if forgotten password does not work for you.
To contact CSA-agent, there are 2 methods:
If ticketing does not work very first time, contact agent directly.
07-04-2022 07:50 PM - edited 07-04-2022 07:51 PM
@Macje you may have to wait 3 hours then try forgot password if it doesn't work you will need to open a ticket, to speak to a customer service agent Click here or if you are having issues with Simon you can send private message to a CS Agent here: https://bit.ly/2GGCJzH
