New phone
07-04-2022 03:24 PM
Do I have to register a new phone everytime I get one with PublicMobile or is keeping the same SIM card good enough?
Thanks
Phones
07-04-2022 08:20 PM
@SallyC wrote:Yes it is my old phone & everything else works but no text no phone. Network setting says Network unavailable
@SallyC In this case, voice calls do not work?
is this a new phone you got from trusted source or private sell?
check if the phone is blacklisted
https://www.devicecheck.ca/check-status-device-canada/
07-04-2022 07:08 PM
Can you connect to wifi and go to settings general about and see if anything pops up.
07-04-2022 07:05 PM
07-04-2022 07:04 PM
Thanks but same type of phone. Iphone 7
07-04-2022 07:04 PM
I am using iMessage, SMS MMS same as before but no luck in sending
07-04-2022 05:46 PM
All your account information is in the SIM.
What is the make and model of your phone? It could be just the setting.
07-04-2022 04:49 PM
@SallyC wrote:Thanks, will give it another try. Can’t text yet.
is voice working?
mobile data working?
you said text does not work, are you sure you are using traditional SMS and not iMessage or RCS? and both incoming/outgoing text not working? Any error?
what kind of phone is your new one and the old one?
07-04-2022 04:46 PM
Only issue may be if you a new phone needs a bigger sim card then you have because you broke it down. In that case you still wouldn't need to do a new activation, just a get a new sim and click on change sim card in your self serve.
07-04-2022 03:35 PM
@SallyC hello is your "new" phone a used phone? does anything work ? what is the make and model
07-04-2022 03:34 PM
If an iOS phone then you likely need to register it to the Apple servers and then either use wifi and cell data with imessage or enable SMS in imessage to also allow standard SMS.
If an Android then maybe restart the phone.
Can you receive texts? That might be something else to look at if you can.
07-04-2022 03:32 PM
07-04-2022 03:30 PM
I tried this but I can not text so was just checking to be sure. Does it take awhile/an hour to connect?
07-04-2022 03:27 PM - edited 07-04-2022 03:28 PM
@SallyC no you just need to change sim card, if its to big it will break apart into a smaller size
07-04-2022 03:26 PM - edited 07-04-2022 03:27 PM
Yup..just move the SIM to your new phone. Make sure you use the correct size of SIM. PM will know what your IMEI number is, as soon as you insert the SIM. Perhaps reboot phone as well and you may have to update the APN settings.
07-04-2022 03:26 PM - edited 07-04-2022 03:26 PM
@SallyC you don't need to "register" the new phone with PM, and same sim card is ok.
Just put your sim card from the old phone to the new one and it should work
