04-26-2020 02:16 PM - edited 01-05-2022 10:32 AM
Hello! Need a bit of help here. I own LG G6 and my mobile hotspot doesn't work for some reason.
To be specific, whenever I try to enable my mobile hotspot, it takes a bit of time saying "authenticating" and it says:
Authentication was unsuccessful. There is a temporary network problem that prevent sthe enablement of the Mobile Hotspot function. Please retry later.
My Mobile connection is fine. I can connect to the internet no problem.
My APN Settings are...
APN: sp.mb.com\
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 392
MNC: 220
Everything else is blank
I've tried adding APN type as dun, and tried adding default,mms,agps,supl,fota,hipri, and tried adding tethering internet APN per this post. I've also tried ticking off "limit mobile data usage", and try to make the WiFi Open instead of locked with password. None of them seem to work. What else should I try? Is this PM problem or my device problem?
04-26-2020 05:53 PM
Some phones just can not tether on PM for some weird reason. See this thread.
Also try the method I've posted in that thread:
Follow the XDA thread on how to change the "tether_dun_required" value using adb, see post #6.
You might want to contact the mods and ask them to check the provisions for your line as well.
04-26-2020 05:39 PM
@gminkwak what are you trying to connect to the hotspot? when you turn the hotspot on in the phone it says authenticating and failed? or your device that's trying to connect to the phone says that.
04-26-2020 05:28 PM
@gminkwak Here are the data set up instructions after a reset courtesy of @geopublic in a previous post perhaps they will help.
@Geneviève It has been reported here many times that when switching providers cetain LG phones need to have their network settings reset for data to work. Check your APN settings to make sure that they are correct.
These are the Public Mobile APN settings you need:
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
Don't forget to save these settings and then select this APN as the active one.
If you need to know where to find the settings:
Android
Settings > More / More Networks / Wireless & Networks > Mobile Networks > Access Point Names > New APN setting (or a plus sign)
04-26-2020 05:09 PM
@gminkwak wrote:I tried that APN type before... didn't work. I just tried it again. Doesn't work unfortunately. I tried adding the dun as well but doesn't work. Not sure why it doesn't work...
That was comma dun no spaces before and after right? And the others without spaces and commas in between? I don't know if order of the terms matters but maybe mms before supl. Who knows maybe even mms,dun before supl.
Are you sure that's all the items? Nothing further down? And you're saving and restarting (or at least flipping in and out of airplane mode)
04-26-2020 04:23 PM - edited 04-26-2020 04:24 PM
04-26-2020 04:09 PM
@geopublic wrote:@gminkwak Change your APN Type: to
default,supl,mms
And restart your phone and test.
Per the subject line...I might suggest adding ,dun at the end of that.
04-26-2020 03:54 PM
04-26-2020 03:46 PM
this is as far as my APN settings go
04-26-2020 03:36 PM
04-26-2020 03:35 PM
Yes I've tried removing and adding my APN (according to the snip you attached below), I have data, my phone didn't automatically create the APN setting after the network reset so I manually added it myself. My data works fine, it's just that mobile hotspot fails at authentication stage when I try to enable mobile hotspot.
04-26-2020 03:33 PM
yes I followed this instruction but doesn't seem to work.. I just factory resetted my phone but that doesn't seem to do the trick either.
04-26-2020 03:11 PM
@gminkwak wrote:yes I have this as my setting but doesn't seem to work.
@gminkwak Remove your current APN, reset network settings and restart your phone. Do you have data? Did your phone automatically create your APN settings? If yes, try turning on the hot spot.
If not, then add the APN as follows:
Make sure data is turned on and you have the correct APN settings.
04-26-2020 03:08 PM
Here is a great site to setup your APN and instructions on how to do it. Find the APN Settings for Public Mobile here!
04-26-2020 03:00 PM
@gminkwak here's an article on enabling mobile hotspot https://www.publicmobile.ca/en/on/get-help/articles/mobile-hotspot
04-26-2020 02:44 PM
04-26-2020 02:40 PM
@gminkwak try these.
APN settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: default,mms,supl,DUN
APN protocol: IPv4
Bearer: Unspecified
MVNO type: Not set
MVNO value: Not set
04-26-2020 02:33 PM
I've already tried this, doesn't seem to work.
04-26-2020 02:30 PM
I don't recall, I don't think I've ever used Mobile Hotspot ever since I switched to PM last year. Just performed the Network reset, doesn't seem to work. Factory reset seems like a lot of work... but I'll try that later once I backup my data.
04-26-2020 02:23 PM - edited 04-26-2020 02:37 PM
@gminkwak Sorry, missed the LG 6 part. But I noticed some errors in your APN settings on your post. Try correcting them.
APN: sp.mb.com
MCC: 302
APN type: default,mms,supl ( if your mobile hotspot is spotty add "dun")
APN protocol: IPv4
Save and restart your phone.
04-26-2020 02:20 PM
@gminkwak wrote:Hello! Need a bit of help here. I own LG G6 and my mobile hotspot doesn't work for some reason.
APN: sp.mb.com\
MMS port: 80
MCC: 392
MNC: 220
Has data worked for you at all since you have joined Public Mobile or started using this phone? LG phones are known to need a network reset or even a factory reset to get data working on them with Public Mobile
