Making long distance call service not working
surinderpathak
I already have long distance addon to call India, have been using it for a while however since yesterday afternoon can't make call. Message comes up long distance charge may apply then next message 6UT1 number not in service
11 REPLIES 11
@surinderpathak  - i believe 6UT1 can refer to the network currently having an issue, which could be cleared up on its own with a bit of a wait time.
Or, the number you are calling is out of service, or they are experiencing a network issue on their end.
surinderpathak
I have already tried that
surinderpathak
I have called these numbers without issue in the past
Hi  @surinderpathak   this is an Indian number you have been calling without problem?
can you call other number in India just to test?
@surinderpathak wrote:
Issue happens with multiple numbers
This might cost a little bit extra but is there any chance to call India using other provider just to see if issue is with PM's add-on or calls in general?
While waiting for any other suggestion, you should contact agent; they might know little bit more why service is not working as expected. Maybe India side has some network issues?
To contact CSA-agent, there are 2 methods:
If ticketing does not work very first time, contact agent directly.
surinderpathak
Yummy
Do you call one particular number only? Can you try calling some other number in India to confirm if calling India is working at all.
RossN
@surinderpathak hi it may be a provisioning issue with your account open a ticket with customer service to look into it for you click here  https://widget.telus.tiia.ai/publicmobile/publicmobile.html
surinderpathak
yes there are about 200 minutes left
DDM69
Have you checked to see if your long distance minutes have been used up?
