MMS
07-19-2022 07:11 PM
07-20-2022 12:43 AM
Open that APN and tap on APN Type and go to the end of the line that probably starts with default and without a space add ->,mms<- and no arrows or dashes 🙂 but be sure to have the comma. Then save it and then go in and out of airplane mode and turn on mobile data and try to send a picture somewhere.
Let us know how it goes.
07-19-2022 11:59 PM
How do I add it
07-19-2022 09:50 PM
Were you ever able to send/receive MMS with your account here? Or did you just discover this problem?
Do you have -> ,mms <- in your APN Type in your APN settings? If not maybe add it. Maybe provide images of your APN settings.
07-19-2022 09:31 PM
tried turn on mobile data,
or go to app message clear cache or clear data but before to do that save all message if you needed, when you do that will be all messages is deleted.
07-19-2022 09:05 PM
HI @jojo7
Please try to do Network Reset
From a Home screen, swipe up or down from the center of the display to access the apps screen.
These instructions only apply to Standard mode and the default Home screen layout .
Navigate: Settings Settings
Tap Reset network settings.
Review the info then tap Reset settings.
If presented, enter the current PIN, password or pattern.
To confirm, review the info then tap Reset.
To test MMS again, make sure Mobile Data is turned on and start by sending a smaller size picture
If that does not work, please post screenshot of your current APN settings
07-19-2022 09:03 PM
Yes, it is
07-19-2022 09:01 PM
Samsung s10+
07-19-2022 09:00 PM
@Willaug56 wrote:Having the same problem but I was able before but now I can't
HI @Willaug56 What kind of phone is that? iPhone or Android?
And how bad is that? just unable to send and receive MMS? How about SMS? or Voice and Data?
You checked and make sure Mobile Data is enabled?
07-19-2022 08:54 PM
07-19-2022 08:18 PM
Also go to your settings and check Settings>Messages>enable MMS Messaging.
07-19-2022 07:56 PM
@jojo7 this is usually what it is, you need your data on to send/receive MMS, so either your network is having issues, or more likely you may have toggled off your data inadvertently. Go into your settings to make sure.
07-19-2022 07:12 PM
@jojo7 Is Mobile data working well?
Make sure you have Mobile data turned on. Sending and receiving MMS requires Mobile Data to be enabled , even it does not really counted towards your data limit
