02-25-2024
07:58 AM
02-25-2024
04:54 PM
computergeek541
Hi! I was abroad for a few days and my MMS seems to have stopped working since switching back to my PM sim.
This has never been an issue before, now the messages just look like they are forever loading.
03-07-2024 09:43 PM
I have a Pixel 7. MMS isn't working on it either. I've tried the APN recommendations below, as well as the one on Public Mobile 's site. Nothing helps.
Can anyone offer any ideas?
02-28-2024 06:34 AM
@TL7 again, you tested you sim on another phone and MMS works??
If so, you might want to wipe your phone and resetup the phone with the PM sim card inside
02-28-2024 05:26 AM
Yep, I've done all of the above now... unfortunately still not working.
02-25-2024 07:38 PM
@TL7 make sure data is turned on
And try Reset All Networks
if still not working, check the APN settings. Compare the APN settings below, try to update it and save:
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
02-25-2024 07:14 PM
I'm using a Samsung flip 4 and there's been no recent system updates that I can recall...
02-25-2024 07:13 PM
Thanks for sharing this article.
I'm on Samsung Flip 4 which shouldn't be impacted by this update?
02-25-2024 12:15 PM
@will13am Agin was just trying To help and I don’t answer every question. BTW might be classier to private message me your pointers .
02-25-2024 12:11 PM
02-25-2024 12:06 PM
@will13am It wasn’t a copy and pasted reply , and I did say “maybe try “ just trying to help
02-25-2024 12:05 PM
HI @TL7
what phone do you have? There was an MMS system thing on Feb 14 and affecting some older phones
And your data , voice, sms are all working and only MMS not sending and receiving?
02-25-2024 12:00 PM
@Handy1 wrote:@TL7 maybe try to reset network settings see if that helps . Doing this will erase wifi passwords and you will have to re enter them
No disrespect intended, consider resetting your canned responses as this one completely missed the mark. As a hyperactive community member you ought to have known the MMS APN settings change that might affect older devices that are no longer receiving OS updates. It hurts your brand when you provide incorrect responses.
02-25-2024 09:34 AM
Please review this article in case it's something which may be impacting you @TL7
02-25-2024 08:13 AM - edited 02-25-2024 08:14 AM
@TL7 What phone do you have, maybe it is affected by the recent changes to settings for MMS? Presumably you have cellular data turned on? Another recent MMS problem seems to have resulted from an update to Android 14, did you do that?
02-25-2024 08:09 AM
