CAN-US-Mexico Plan doesn't work
Abigsmae
Hello! I'm in Mexico right now with the CAN-US-MEX plan and it keeps popping up that my roaming is off. It says I'm connected to "TelCel" but I can't access my data. I can phone and text message but my cellular data does not work. How do I fix this?
bao_tista
Hey I just followed these instructions and still have the issue. No signal of any sort.
Abigsmae
@hTideGnow Thank you so much!!!!
hi @Abigsmae
btw, you have two lines, Primary and Travel.  is the Primary your Public Mobile line? if it is click on it and what do you see?
and to manually try different network:
  1. Open Settings
  2. Tap Cellular or Mobile Data
  3. Tap Cellular Network or Network Selection
  4. Toggle off the Automatic switch
  5. Select your desired carrier from the list of available networks
Abigsmae
Hello @hTideGnow thanks for the response! I can't seem to find that tab under my cellular settings on iPhone. Can you please show me where to find it? I included a screenshot to show you.
HI @Abigsmae
make sure you Roaming Mobile data is enabled on the phone.
and you can also manually connect to AT&T and test again
