02-27-2025 02:42 PM
Please help as even though my old number transfer was completed by rogers still no note work on my phone from public mobile
02-27-2025 03:52 PM
self solution removed
02-27-2025 02:59 PM
if have only Asian version of Oppo A7, the V1 or V2, then it is not a phone designed for North America and you won't be able to use it on PM network
you might be able to use it only on 3G, try changing your network mode to 3G and test
02-27-2025 02:50 PM
I am using Oppo A7 android 8.1
02-27-2025 02:46 PM
I tried but still no network on phone. I used different handset for public mobile
02-27-2025 02:45 PM
Hello,
If your number transfer from Rogers is complete but you’re not getting any network on your Public Mobile phone, try these steps:
02-27-2025 02:45 PM
HI @ArpitGupta
what phone do you have? esim or physical sim
Please first Reboot the phone and Reset Network settings?
if same, then you will need PM support agent to help to refresh the account , you can submit ticket by direct message:
02-27-2025 02:45 PM
Did you remove your Rogers SIM from your phone?
02-27-2025 02:44 PM
this is not related with porting but a problem with the setup
try Reboot the phone first and test making calls
if you need further help, ask PM by message them using this link:
