06-08-2022 01:26 PM
I have recently changed my plan and my loyalty rewards were not applied to my most recent bill. How can I get my rewards applied to my bill?
06-08-2022 10:24 PM
Keep us updated on how this gets resolved as I am having my own rewards issue right now lol
06-08-2022 02:05 PM
If you scheduled a change plan on next renewal then your rewards should have applied as usual. If you changed your plan now then you started a new 30 day cycle so your rewards do not apply until next renewal once you have completed a full 30 day cycle.
06-08-2022 01:40 PM
HI @Bernadettec If you have never migrated onto the new reward system, please open ticket with PM CS Agent
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
06-08-2022 01:37 PM
If you changed plans "now" then the rewards don't pay in automatically. If you had possibly used the lost/stolen function then the rewards need to be added by the support people.
Are you possibly on the $10 plan? Did autopay possibly take $8 instead of your usual $5?
06-08-2022 01:33 PM
I had a $3 loyalty recognition credit and a $2 auto pay credit each month.
06-08-2022 01:28 PM
@Bernadettec Any chance you also changed your reward to go with the new Rewards system (Public Points)?
If you are still on the old system, you should be getting all the reward as usual, open ticket with PM Support to have them confirm:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
06-08-2022 01:27 PM - edited 06-08-2022 02:20 PM
@Bernadettec hi changing plans shouldn't effect your loyalty rewards
