New phone Samsung to use with Public Mobile
TayLukas
I bought a Samsung Galaxy A22 4G LTE from Walmart. Can it be used with Public Mobile? I already activated a line.
Thanks.
JL9
Yeah that will be more than sufficient to work with PM
HI @TayLukas
Here is the frequencies on your phone BOLD are the compatible bands
3G bands HSDPA 850 / 900 / 1900 / 2100
4G bands 1, 2, 3, 5, 7, 8, 20, 28, 38, 40, 41
Yes, A22 will work on PM, but it might not work great with 4G
Any phone should ideally have 3G B2, B5 and LTE B4 (or B66 instead of B4), B12 (or B17 instead of B12) for minimum coverage.
This is not a phone designed for North American.  Again, it will work, but might not work great in some area.
Also, is it sold by Walmart or Walmart marketplace?  Be careful if you are going with Marketplace.  There are some risk buying from marketplace
TayLukas
Thanks for your prompt answer. I'll try my new phone soon!
MrSpock
@TayLukas hi yes you should have no problem with that phone 😀
