Spoofing
afacundo
How do I report spoofing to Public Mobile?
hi @Thalia1997
no petition needed.  this is something no carrier can stop.. not evening the government .  Don't waste time
Thalia1997
Darn that's too bad. We should petition for it.
@Thalia1997 wrote:
 there is something you can set up on your phone where the caller has to press a nunber or say your name before the call will get through to you. they only have to do this once, and spam calls will not be able to. when they call again they won’t have to do it again, but it helps a lot !
Public Mobile doesn't offer this function. I think Telus does though
Thalia1997
Meow
There is NO point as PM cannot do anything regarding that activity. So whoever sees your number at it is NOT you has to live with modern scammers.
hairbag1
@afacundo
it's a common occurance these days. I suggest just not answering any calls unless you actually recognise the callers number. If it's a legit call, they can leave a voice message and you can return the call if you wanna.
