Lost phone
06-06-2023 09:53 PM
My kid lost their phone. I can't log in to my account because it sends a code to the phone that we don't have. How do I cancel this thing??
Thank you
My Account
Service
06-07-2023 01:17 AM
So I just did exactly this.
Go to login page. Select forgot password. It will send a code to the email address and you can update the password.
Try to login again and it will send a code to the phone again. Click on resend code and now there is an option for send code to email.
06-07-2023 01:00 AM
I stumbled on a work around. As far as I recall I updated my password and then got the option to get an email for the code.
06-07-2023 12:34 AM
I wasn't sure, so tried to sign up. It seems that I did set it up, as I did on my other 2 phone accounts. I only get the text or voice message options to login. I can access the other accounts I set up.
06-07-2023 12:20 AM
Yes, I have an account and am signed up. I have a total of 5 accounts and have no problems accessing the other accounts because I have those phones. I can't access my own account because the only options are text and voice mail. I'm looking for the work around for that.
06-07-2023 12:11 AM
You need to create an Eversafe ID first before you can login to your account.
Click on Sign Up on the PM website.
06-06-2023 11:55 PM
Hitting resend gives you an option for text or voice message. You're then kicked out. How do you get beyond that to log in?
06-06-2023 11:46 PM - edited 06-06-2023 11:52 PM
Did you create a Eversafe ID? You need to create it first before login to account so click on Sign Up and use the registered email and password. The 2FA code will be sent to your email.
Once everything is completed then you can login to your account and click on Lost/Stolen phone in the Profile section or replace SIM card number when you get a new SIM and phone.
06-06-2023 10:43 PM
if you've sent a message to CSA about the account, they'll want specific account related info to prove you're you. ie: phone number, account number, name on account, alternate phone number. pin number..etc.
Watch the little envelope icon on top right side of page will be highlighted when they sepond.
06-06-2023 10:29 PM
I tried resending the code, but never gives the email option. I do have access to the email associated with it though.
I've sent a private message to customer support.
Thank you
06-06-2023 09:58 PM
@brokenaxle1 - can you hit 'resend code' multiple times. After which you should be an email option. That is if your son ever had their My Account registered for.
See how to report lost / stolen: https://www.publicmobile.ca/en/on/get-help/articles/lost-or-stolen-phone
Once a new SIM and phone is obtained, see "How To Change Your SIM Card" in this Help Article: https://www.publicmobile.ca/en/on/get-help/articles/change-sim-number
If still issues, to contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them:
1 - Normally Faster use this link to: Get Help With Public Mobile Chatbot
OR
2 – Slower - Use this link to:
Contact Public Mobile Representatives (CSA) by submitting a message(ticket) to them here: Private Message to Public Mobile Customer Support Agents (CSA)
CSA contact methods also found here in Help Articles for future reference:https://www.publicmobile.ca/en/on/get-help/articles/contact-an-agent
