Call forwarding to Fongo
PierreCarl
i'm trying to get my Android phone to forward calls from my Public Mobile number to Fongo number. I've put the *21*number# but I get a "unexpected server response" why would that be? what am I doing wrong?
8 REPLIES 8
PierreCarl
Thank you all for the input. After fiddling with it and re-installing my Fongo app, the only option that works is for all calls to be forwarded.
RavingRaven
@PierreCarl
Have you tried using the call forwarding options in the settings of your phone app? I was able to call forward (Always forward) to both a Fongo and a Public Mobile phone #.
As stated conditional call forwarding (when busy, unreachable and unanswered) did not work and defaulted to my voicemail.
Dunkman
@PierreCarl
From my understanding, conditional call forwarding is not working. The rest of the call forwarding should be fine.
Maybe try call forwarding to another number besides Fongo.  To see whether it might be an issue on the Fongo end.
Ok use this link then. I dont know if they can fix it. The forwarding has been broken for years and they are aware. Are you currently in Canada? You have to be for it to possibly work.
PierreCarl
I clicked on the link you provided and followed the instructions the chatbot laid out. None of it works. 😞
Chalupa_Batman
Hello @PierreCarl
Here's the link on call forwarding just to make sure you're doing it correctly.
Call Forwarding
Only unconditional forwarding still works...    apparently.
PierreCarl
Oh wow! Well, in that case I'll have to move my number to another company.
Sansan
The calling forwarding feature has been broken for years now.
Maybe contact agents and see if they can fix it for you.
