@cs_agent
06-06-2023 07:23 AM
06-06-2023 09:51 AM - edited 06-06-2023 09:55 AM
Indeed - the ongoing differences between mobile and desktop browser presentations.
EDIT: I think the direct link to one’s own mailbox works on any browser presentation. 😉
06-06-2023 09:46 AM
@HALIMACS wrote:Oh, I’m all about sending people to the right location too, @esjliv
A 1-click option is more direct.
When I click on that link you provided, I don’t see an option for one’s own private message box there.
@HALIMACS - if you are mobile the envelope doesn't show, but if OP / @Jax0904 is on desktop then their envelope will show on the top right corner.
But if OP is on mobile they have to tap on their avatar to see their messages.
06-06-2023 09:42 AM
06-06-2023 09:29 AM
Yes that works too @HALIMACS .
Just trying to point members in the right direction to find that location, so they know how to do this themselves. 🙂
06-06-2023 09:15 AM - edited 06-06-2023 09:20 AM
That takes the OP to their profile page @esjliv
Does this link not work, for a 1-click redirection to one’s own private message box?
06-06-2023 08:25 AM - edited 06-06-2023 08:25 AM
As before, @Jax0904 , check your private messages which is where customer support will reply.
Here’s the link again:
06-06-2023 08:25 AM
06-06-2023 08:24 AM
Did you mean to reply to an agents message @Jax0904 ? Go here and locate your envelope to check your messages:https://productioncommunity.publicmobile.ca/t5/user/viewprofilepage/user-id/294154
06-06-2023 08:23 AM
Check your private messages here:
06-06-2023 07:43 AM - edited 06-06-2023 07:44 AM
06-06-2023 07:41 AM
Than you
06-06-2023 07:39 AM
@Jax0904 wrote:Good morning has there been any luck
@Jax0904 Not sure what you are looking for but this isn't a chat board with CS agents. We are just fellow customers. If you have an open ticket you need to communicate with them through there. Otherwise open a ticket by selecting "Get Help" and then "Contact Us".
06-06-2023 07:37 AM
Goos morning is there anyone available to help yet??
