Lost phone and process to retaining the previous public mobile number
jad2224
Hi,
My son recent lost his phone which had a public mobile sim. He is not able to log in to his gmail account and also lost access to the public mobile account. We have used automatic payment linked to his debit card.
We now bought a new public sim card and phone. Please advise us how we can retain his old public number so he can gain his access to his gmail account.
Thanks in advance!
10 REPLIES 10
@jad2224  Yay glad you got it all sorted out
jad2224
Thanks so much for the suggestion @esjliv . I was able to resolve the issue and retain the number.
jad2224
Thanks so much for the suggestion @Handy1
jad2224
Thanks so much for the suggestion @hTideGnow
jad2224
Thanks so much for the suggestion!
HALIMACS
@jad2224 wrote:
Hi,
Thanks in advance!
@jad2224
Is there a reason you're unable to log into self-serve?   Did you have two factor authentication set up to send an SMS to the device?
If so, follow @esjliv information to contact Customer Support to give you access to self-serve, and while they're at it, they can associate the new SIM card to the account.
If no 2FA is enabled, try logging in to the account using the e-mail account and password AFTER going incognito or private tab.   It doesn't matter if the associated e-mail account is defunct as the e-mail address for log in here is simply a username and doesn't need to be associated with an operable e-mail account.
Hi @jad2224
since you son has no access to the email, you need to open ticket with PM CS agent to ask them to change the email login to another email address first.  Maybe on the same ticket you can ask PM agent to change the SIM card on the account as well
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
@jad2224  Do this on a computer swap sim number do not activate it
My account
Legend  and features
Change plan / update cc /auto pay
Account #/ change # port /swap SIM
once your logged in again if you need help to change email you need support for that but first try using forgot password reset and try different emails you think you used to join on I initially and see if your email gets reset code
support
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here
  • you can send a private message to our  CS_Agents by clicking here.
@jad2224
See "How To Change Your SIM Card" at the bottom of this Help Article: https://www.publicmobile.ca/en/on/get-help/articles/sim-swap-fraud
BUT, since you cannot access his My Account, perhaps submit a ticket this way to do so. And also request to get access back to his My Account. Click here to request a SIM Swap with the Public Mobile Customer Support Agents (CSA): Submit ticket for a SIM SWAP
