Long distance minutes
Bruce8
I have unlimited Canada wide minutes in my plan, when I try to make a long distance call in Canada I get a message telling me I have used all my minutes!  What gives?
Thanks in advance for a response.
JL9
Little errors happen like this, hopefully the reboot resolves it bc although adding the one sometimes fixes it too, it is kind of a pain lol
Meow
Ignore that message and try few different options:
- Reboot phone or toggle airplane mode on/off.
- Add 1 in front of area code.
darlicious
@Bruce8
This is a common glitch. Reboot your phone. This should take care of it. Try calling a frequently called phone # by manually dialing the number including the (1) in front of the phone #.
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here   ....for additional member supplied info.
HI @Bruce8   it is a common glitch
Usually a device reboot would resolve the issue.  Please try
