Login issue
sruffell
My login is no longer working,I’ve reset the password three times, still doesn’t work
Timer
@sruffell
use browser from computer, and clear cache and cookies and use one page inPrivate mode,
and check out your email spam,
popping
1.  You have 3 attempts for the same received code.
I suspected that if you request password reset too quickly, PM server may be confused and still using the password provided by previous reset.  This just my guesstimate.  I had seen this issue reported with the new self-server portal.
2.  Try the password reset using another browser.  I found that the new self-serve portal does not work well the Chrome browser on my Windows 10.
3.  Create a support ticket, using procedures listed in the earlier posts on the thread,  to ask for CSA help
HI @sruffell   you got the code and you reset a new password, right?
DO NOT reset it further
Now, try to use either Incognito mode, or a completely different browser from the one you were using to login before (Edge/Firefox/Chrome), then use the last password you have reset to and see if you can login
It might work, it could be just a cache issue
If that fails, open ticket with PM Support and have them to reset it for you once more time.  But again, try to login from a Incognito mode (or even another device)
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
MrSpock
@sruffell hi if you are not having any success  then get a cs agent to reset it for you,  you will need to open a ticket, to speak to a customer service agent    Click here or if you are having issues with Simon you can send private message to a CS Agent here:   https://bit.ly/2GGCJzH
