07-25-2022 02:57 PM
07-25-2022 04:17 PM
Try the reset password link on the login page. You have 3 attempts for the same received code.
07-25-2022 03:01 PM
@Jon420 hi if you tried forgot password or tried to many times you may be locked out,it takes 3 hours to reset , if you are still having issues(alot of people are today) then get a cs agent to reset it for you, you will need to open a ticket, to speak to a customer service agent Click here or if you are having issues with Simon you can send private message to a CS Agent here: https://bit.ly/2GGCJzH
07-25-2022 03:00 PM - edited 07-25-2022 03:01 PM
do you have problem with the password or you know the logins but the system keep giving weird errros?
If it is just the errors but you are certain the password, try using Incognito mode or try on another browser (Edge/Firefox/Chrome) or try on another device
If you just do not know the password or login name, try to self-reset it at
https://myaccount.publicmobile.ca/en/forgot-password
Just put any email address you could have used and see which one work and get you to step 2
If none of them work, open ticket with PM Support
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
