10-25-2022 12:29 PM
I can’t log in to my account and this is happening every month! Anyone else having that trouble?
10-25-2022 04:34 PM
@faithmoorcraft Have you contacted support if you're unable to reset the password? Here's couple of links, try chatbot first: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Or send private message to CS_Agent if unable to submit a ticket: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
10-25-2022 04:32 PM
First, it says wrong email or password and it isn’t . So I try to reset the password and the. It will say password reset failed and try again later! It’s been doing that every months and I have to get help
10-25-2022 04:06 PM
Please give some details. What is happening when you try?
10-25-2022 12:44 PM
No problem here. Try clearing your cache, cookies and go incognito on your browser.
Website is very glitchy just like the Federal Government website.😤😡
10-25-2022 12:33 PM
Try using different browser. Try Incognito mode. Clear browser’s cache. Try forced refresh.
10-25-2022 12:31 PM - edited 10-25-2022 12:31 PM
@faithmoorcraft hi yes it is an ongoing problem hopefully it will be rectified soon in the meantime try a different browser in secret or incognito mode reboot your device and try to log in again
