08-05-2026 10:29 PM
Went to pay my phone bill and selected a plan by mistake. now it wants me to change my number. i don't want a new plan. I'd like to cancel the plan that was selected by mistake.
08-06-2026 11:47 AM
We appreciate your escalation. An agent is already assisting the customer and will ensure they receive the support they need.
08-05-2026 10:39 PM
The error indicates that the Eversafe login system is unable to locate your My Account from your email login. But no worries, it is an easy fix for PM support, usually you will just need to engage them by direct message:
But I have escalated your ticket on your behalf. PM support will reach out to your via Community inbox. Please monitor here for their reply:
(Since it is a bit late tonight, they might not reply you until tomorrow morning)
08-05-2026 10:38 PM
you'll need Customer Support to help with this. Use this link to dm Customer Support... https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
They will reply to your Community inbox within 2 to 4 hours, please check your inbox here:
They're gone home now so expect their reply tomorrow am.
08-05-2026 10:38 PM - edited 08-05-2026 10:38 PM
@Gerri5 - You may either have:
I would suggest contacting a Public Mobile Agent:
⬇️ Click the link for an Agent * ⬇️
* - CS_Agent will typically get back to you within 48 hours. They work 7 days a week from 9 AM to 10 PM EST. You will be required to login to your Public Mobile Community Account to contact CS_Agent. Please monitor an agent to respond back to you. They may notify you asking for some information through Private Message, in your community mailbox by clicking here: Mailbox
