05-27-2024
07:03 PM
05-27-2024
09:25 PM
computergeek541
Got my sim card and paid for subscription. Can't activate sim card through app: it gives me the runaround. It tells me to log in, but I am logged in. It tells me to "Get support", but it doesn't work. Can anyone please help?
05-28-2024 08:49 PM
Not yet. I did message someone at the link that hTideGnow sent and got a response, but am waiting for a solution to the problem.
05-28-2024 03:53 PM
did this get resolved? I'm having the exact same problem.
05-27-2024 07:19 PM
hi @HiGoofy
yes, you need support agent to help to complete the setup on the account for you
you can open ticket if you use the link I posted above to message them. Here is the link again
05-27-2024 07:16 PM
Yes, I used the app and completed everything, but it says "Step 6 - Subscription not activated. Something didn't go right while activating your subscription. Click below to contact a customer support agent." So I've done that quite a few times but don't get any help.
05-27-2024 07:08 PM
HI @HiGoofy
are you using the Public Mobile app? at this stage (after you got the sim card) you need to use the app to complete the activation.
or if you have trouble still, ask support agent to help
05-27-2024 07:04 PM
PS: I'm told to "Get support", but that doesn't work either.
