03-28-2023 06:19 PM
When I access the login page on my PC, I get a messed up page that is clearly broken. Broken login page
If I try to log in anyways, I get this.
It would be nice to be able to log in to my account!
03-28-2023 07:28 PM
When you access the login page on your pc you encounter errors....so when you access it on your phone you have no issues? If @softech's suggestion doesn't help then use a different device after you clear your browser and reboot the device.
The pm login page is fussy.....you can also try:
03-28-2023 06:52 PM - edited 03-28-2023 06:53 PM
This may go without saying, but I gotta ask @demetriel :
If you activated some time ago in-store, it's possible a self-serve account was never created. To do that, you'd need the Customer Support Agents to help in creating one.
03-28-2023 06:48 PM
i would call that page broken since it doesn't work with normal firefox like any other website, but does work in private mode
03-28-2023 06:29 PM
@demetriel the login page didn't break. You are using some kind of Chrome extension, such as theme of some kind that is incompatible with PM page
Try to launch the browser with no extension mode and it should work
or try on another desktop browser with no extension installed and it will work
03-28-2023 06:25 PM
@demetriel Try clear caches then using private mode try again.
