Locked out
Brenda19
My husband's credit card expired and now he is locked out of his account. He cannot update his credit card info because a security pin is sent to his cell which he is locked out of. We cannot get a hold of anyone to update information either. Any assistance would be GREATLY appreciated
7 REPLIES 7
Brenda19
thanks for your help, appreciated anything at this point
@Brenda19
Try these workarounds, it could bypass the SMS in linking My Account with EverSafe ID
  1. Reset your password to self service account. Once reset, sign in again with new password. Might be able to receive 2FA via email instead to gain access.
    (!!!You will need to click Resend Code and then Send email to trigger the 2FA to email)
  2. Potential workaround (for some): If you don't have access to SMS OTP, try entering an incorrect OTP code 4 times. For some individuals, this is giving the option of an email instead.
If none of those workarounds helps,  please open ticket with support by direct message here:
@Brenda19 wrote:
email was not an option. it is asking to send a voicemail or text
HI @Brenda19
then I guess ticket with agent is needed.  Please submit as per above
Brenda19
@Brenda19  Fastest way to get  you up and  running again is to buy a voucher and load to account *611 or get support to update the credit card info for you
send a  private message   To CS_Agents click
HI @Brenda19
try using email to receive code.  On that 2FA screen, click Didn't receive code and select email as the option
if the option is not there,  please submit a ticket with CS Agent here and they will sort it out:
will13am
@Brenda19 , if you select resend code, you will be offered the option to receive the 2FA code to email.
