10-15-2023 06:04 PM
I have been locked out of my account for over a week and trying to login just tells me to wait until its unlocked but its been a week. i have tried 'customer service' and it does not help as always requires a login which i cannot do. i am only able to post this on my daughter's login. forgot password does not work either.
10-15-2023 08:28 PM
HI @Tony68
can you provide us a screenshot? can tell you what is the problem if we see the exact error message. There are different ones.
10-15-2023 06:18 PM
10-15-2023 06:13 PM
Recommend setting up an Eversafe login for a Community user so you can more readily communicate with Customer Support Staff.
Follow this link:
10-15-2023 06:13 PM
Has this been an issue since you first created your eversafe ID?
10-15-2023 06:08 PM
@Tony68 were you using browser to login. ? Try using Incognito mode and see if it helps, or try using app
if that does not help, please engage support by direct message:
10-15-2023 06:07 PM
try this link to message the CSA folks for their help. Watch the little envelop icon on top right side of the page will be highlighted when they respond.
