Legacy Plan - seconds of talk time is rounding up
ashutosh06
For emergencies, I have a legacy plan with 50 mins of talk and 50 text messages for my child. I was recently checking the usage and saw that when I called my child and it went to voicemail for 3 seconds, it showed a talk time of 30 seconds on public mobile's usage (website). I am baffled at this usage report. I am confused and frustrated with this type of usage summary as I cannot even use the full 50 mins allocated to talk with my child. I need support on this by public mobile customer service.
@softech @J_PM @Dave_M
1 ACCEPTED SOLUTION
Accepted Solutions
Timer
@ashutosh06
seconds of talk time is rounding a minute
e.g.  02:05 is call 3 minutes  or 06:40 is call 7 minutes
and you call to your voicemail is also taken from your minute
so if you like to change your plan to unlimited /Canada-wide minutes
14 REPLIES 14
Lux
Try refreshing the stats. There should be a small refresh button.
You can contact a representative by doing the following:
RossN
@ashutosh06 hi it doesnt matter what provider you are with ,the limited talk plans are rounded up to 1 minute even if you only use 4 sec or 54 seconds
Timer
@ashutosh06
will13am
@ashutosh06 , minutes have been rounded up to the nearest whole minute for as long as I have been a customer.  This is not a recent thing.
dust2dust
Think of the usage details as a report of all the activity on your account. The overview page number is the one you want to focus on. Inbound calls that go to voicemail do not take your minutes.
It's also highly recommended to get the $5 500 minute Canada-wide calling. Great add-on for limited minute plans at 1¢ / minute.
ashutosh06
Thank you @Timer, @RossN  for your explanation. I did not know that this was the care as I've always had an unlimited talk/text plan and I never bothered to look at the online usage report for my child's public mobile plan.
Timer
@dust2dust @ashutosh06
at  Terms and conditions for plan
#5.Calls to voicemail will deduct from in-plan minutes.
@ashutosh06    Since you are on a grandfathered plan, if you do opt to change it, then you won't be able to change back to it as it's no longer offered.  However, depending upon the usage and because PM increased the price for this plan by 30% a few months ago, perhaps the $15 plan would offer more value for an additional $2/cycle.  Of course, it would be still cheaper if the usage is nominal to just add the $5/500 mins as back up mins since they don't expire.
JL9
You can also save some minutes by calling from another phone or evn a free VoIP app to check your voicemails for that number
