08-10-2022
11:16 AM
08-10-2022
06:37 PM
computergeek541
08-10-2022 04:51 PM
go to create a My Account
and
click
Contact Us
and submit a ticket,
if getting a error for submit ticket then contact support team by private message CS_Agent
08-10-2022 11:34 AM
@Maddy79791 wrote:It's take me to a page for issue a ticket which I have been doing . Is there any customer support on call where I can trouble shoot
HI @Maddy79791 message them and make sure you check the inbox here (top right , envelope)
08-10-2022 11:32 AM
I have been trying since 25 days but no help . I guess I will go with other provider . Thank you
08-10-2022 11:29 AM
08-10-2022 11:29 AM
@Maddy79791 wrote:I tried but no help
I have the step by step for you above
But if it is confusing, then just message PM CS agent directly:
08-10-2022 11:27 AM
did you activate in store? if you activated yourself online , you should have a My Account setup already.
But if you activated instore, then, yes, likely it wasn't created and you need to:
To set it up now, go to My Acccount site and click Register now (or this link: https://urlshortner.tiia.ai/XZxMjt) and follow the steps below:
- You will have to come to this direct link to open ticket with CS agent
https://urlshortner.tiia.ai/XZxMjt - Click "Contact Us"
- and then Click "Click here to submit a ticket"
- you will then direct to another page to open ticket.
At Step 1. Select an issue category , leave it with Password & Username Reset there,
Click Change my Self-Serve email and the click Next
At Step 2. Complete additional issue details, enter a email address you want to setup to login to My Account and pick one of the questions to answer to validate yourself
At the same step, you can choose to accept live chat or not, and click Next
In the next step to Verify your identity, click Verity by SMS Code, enter the phone number and Send a code
click "Submit Ticket" to complete the process
08-10-2022 11:25 AM
I tried but no help
08-10-2022 11:20 AM
