08-31-2021 05:36 PM - edited 01-06-2022 03:16 AM
Hello,
I want to switch to a new company and keep my number, but I lost my SIM card and was told I would not be able to complete the process without it. Is there a way to confirm the transfer of the number to the new company without the SIM card (maybe via email?). Secondly, I have cancelled the AutoPay in my account, is this enough for ending my business with Public Mobile? Any help would be much appreciated, I am really at a loss without any support and no one to talk to.
Thanks!
09-01-2021 09:40 AM
@arielspalter Yes, this is the proper way and likely less hassle than asking PM for a favour to port without a SIM
Just logon to My Account and click Check SIM and use Email for getting the 2FA
more details:
SIM Swap Fraud: 2 factor-authentication - Community (publicmobile.ca)
09-01-2021 09:35 AM
Thank you! even though I've already purchased a new SIM card I am now trying to do it this way since it seems faster. Will see how this goes...
08-31-2021 06:27 PM - edited 08-31-2021 06:27 PM
Yes and yes. @Spudster gave you the correct info as a new SIM card is not necessary. Contact customer support and "verbally" authorize the port or in pm's case you will be giving written authorization.
Not nearly as difficult as @computergeek541 makes it out to be....and less costly. Save the SIM card in case you choose to return to pm sometime in the future. Your account does need to be active to port out.
08-31-2021 06:08 PM
When is your next renewal date?
1. You should keep your PM account active before you can port your number to the new provider. Therefore, If your new SIM card has not arrived the day before your next renewal date, you should add fund to your account to keep your account active.
2. You should also keep your new SIM card in your phone after you initiated porting your number to your new provider. You need to confirm the port request text message from PM before PM release your phone number to your new provider.
08-31-2021 06:00 PM
You could have also contacted the Customer Service Agents to advise that you wish to transfer out of public mobile and will be unable to respond to the SMS port authorization text.
There are situations when people lose their phones or SIM card and they are not required to have to buy another one to port out.
And yes, removing auto pay will ensure your service will not renew.
08-31-2021 05:57 PM
it's ok,
if you buy it online from PM is take maybe 4 week..
but i suggest you get a New SIM card is better for you and fast way
from any Retail store and you buy it right away,
Where To Buy A SIM card,
You can purchase a Public Mobile SIM card at a variety of retail locations. Click Here link
to open our store locator and find the closest retailer to you.
or
Too easy buy it from any gas station near me,
08-31-2021 05:54 PM
Thank you! I somehow got confused and thought I posted it in the wrong place. I've ordered a new SIM card and will do the switch when it arrives.
08-31-2021 05:48 PM
buy it a new SIM card for PM and Swap and after that you can transfer old number to new company, if you need your old number,
or if you don't want it, just remove AutoPay from your acccount and the account with 91 days will be closed....
so how many poster you will do just keep it in one !!
08-31-2021 05:43 PM
Hello,
Thanks!
08-31-2021 05:42 PM - edited 08-31-2021 05:43 PM
08-31-2021 05:40 PM - edited 08-31-2021 07:27 PM
@arielspalter wrote:I want to switch to a new company and keep my number, but I lost my SIM card and was told I would not be able to complete the process without it. Is there a way to confirm the transfer of the number to the new company without the SIM card (maybe via email?). Secondly, I have cancelled the AutoPay in my account, is this enough for ending my business with Public Mobile? Any help would be much appreciated, I am really at a loss without any support and no one to talk to.
The easiest way may be to replace the Public Mobile SIM card. Otherwise, you're looking at a rather complicated nunber port out.
