Latest update clarification
Beanieb
I recently updated my APN
There were 2 different posts.
1. Mmscproxy....one place says to put mmscproxy.mobolity.ca, the other says 74.49.0.18.
2.MMS port 8799 vs 80
One setting causes data to work improperly,  the other I get no MMS messages.
Is there something to get it to work properly?
Thanks
2 REPLIES 2
hi @Beanieb
the updated proxy is mmscproxy.mobolity.ca and port is 8799
@Beanieb
1. just the IP and name, same, better to use the name
2.8799
here is the full APN
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
         or    default,mms,agps,supl,fota,hipri
           (might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enabled
                or  Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
