Landline can not call in my new transferred phone number
XO2024
I had transferred my phone number from FIDO yesterday. The activation seems not bad. I can use my new phone number to call and receive phone call from mobile phone provider. But when I try to use my landline to call my cellphone number. It failed. And I tried to use another Landline to call in. Failed again. The message is "the number you dialed did not assign". How can I contact the port in Team? Thank you!
@XO2024
yes, as long as you are receiving calls from another provider, the porting is completed and no concern
reboot your VoIp box daily if possible and test calling your ported number, it will work in the next day of two
XO2024
Thank you! If this is the case, I had to awaiting for more time because my landline is VoIP.  But a couple years before, when my wife transferred in her phone number from FIDO, there was no such issue at that time.
Anyway, Thank you for your opinion!
@XO2024 can other phones call you number ??  Just incoming calls fr9m landline a problem??
and is your landline a traditional lines like Bell or Telus landline?? if you are one of this VoIP Homephone lines like Fongo, Ooma, then it will take them 2 to 7 days before they can know your number changed provider and route the calls to you correctly.  Those VoIp providers do not update their tiutrsbas fast as the bigger carriers
XO2024
Sent! Thanks!
@XO2024  Submit ticket with support
send  a  private message   To CS_Agents
