09-29-2025 02:34 PM
09-29-2025 02:51 PM
Hello @ Rwdygrl,
I sent you a private message. You can view and reply to it by accessing this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
09-29-2025 02:43 PM
I have escalated your ticket on behalf. PM support will reach out to your via Community inbox. Please monitor here for their reply:
09-29-2025 02:43 PM
I appreciate that but the plan I have set for renewal doesn't give me the option to renew now and it isn't now in the shop options to get it again
09-29-2025 02:38 PM - edited 09-29-2025 02:39 PM
@Rwdygrl wrote:I've put 3 tickets in to change my plan early and not getting response
Hello @Rwdygrl
You do know that Public Mobile is a self serve service and you can change your plan at any time yourself and it can start either immediately or at the end of the 30 sub. They will give you two options when you pick the plan you want. You don't need a CS Agent to help with that.
09-29-2025 02:37 PM
Yesterday and now another 3 hrs ago
09-29-2025 02:36 PM
hi @Rwdygrl
did you check the community inbox here?
and when did you put in the 3 tickets? Support agent usually reply within 2 to 4 hours
