LTE Speed
Eason
What’s with the LTE speed? It’s so slow. 2.78 Mbps?…
Meanwhile my wife’s phone with F**o is much more reasonable at 71 Mbps
7 REPLIES 7
Kristowhy
@Eason wrote:
Tried that. No help
You still have not said what plan you are on
Also try using speedtest.net site or bet yet the speedtest by Ookla app
Eason
Tried that. No help
dust2dust
Speed is dependent on the plan. If you're on a 3G speed plan then you will get that 3megs speed. If you're on a 4G speed plan then yes you should see upwards to 100 megs. If on a 5G speed plan then what is it 250 megs.
Then, if you have recently changed the plan speed then that usually takes a couple days to be noticed.
@Eason
I see you are on LTE.  But even you are on 4G plan, you can try the 5G network (every PM subscribers can access 3G/4G/5G networks, just the speed will be capped accordingly).  So, try select 5G Auto on your Network mode and see if it improves
@Eason
LTE=4G
Try rebooting your phone by powering off then back on.
HI @Eason
you are still on 3G speed
are you using iPhone, update the Carrier profiles
Reset All networks by
Settings > General > Transfer or Reset [Device] > Reset > Reset Network Settings
and test your sim on your wife's phone
@Eason
speed on LTE should be around 100Mbps
Try clicking Reset all networks and try in different area and see if you get different experience
