Plans
07-20-2023 03:16 PM
I would like to know why the Canada-US plan which allows calls, data, texting while in both Canada and the US is only available to Quebec? Freedom Mobile offers more or less the same plan across Canada, why is yours only offered to Quebec??
Plans
07-20-2023 03:46 PM
@Doug12 It was when it first appeared . But for now it’s available to all provinces . If you like it jump on it while you can . Just be sure to change plan for next renewal and not immediately. Or you lose money on current cycle
07-20-2023 03:37 PM
I went through every region and the $50 plan was there. Quebec had a few more options. I went into change plans on my account (in BC) and the $50 plan was there.
The fine print is the list of all the references with the little symbols in front. That Quebec only footnote links to that symbol on the Quebec only plan in the Quebec region.
Have you selected the 5G tab for the plans list? Select All or 4G and the plan should be there.
07-20-2023 03:28 PM
It will not let me select this plan - it does not show it even as an option when I am signed in to my account. In the fine print there is a statement that says data and calling etc apply whether in the US or Canada but it does not say which plan it refers to. If I go in not signed in it shows me the Canada-US plan which it says allows both data and everything else on both sides of the border. In other words no roaming charges. That is plan I want but cannot get to it. On the details on the not signed in page, it says that the plan is only available to Quebec?
07-20-2023 03:21 PM
the fine print was a template that copied to all plans 😞
that point is for line with ⁺ , but the plan we are viewing does not have that
So, no worry, the plan is confirmed for outside of QC as well
07-20-2023 03:20 PM
Good of you to read the fine print. That is the footnote to the reference of one plan in the Quebec list of plans.
07-20-2023 03:20 PM
Did you change the province location on website for existing customers or on the PM app for new customers?
It is available to all provinces.
07-20-2023 03:19 PM
The fine print currently says only available to Quebec?
07-20-2023 03:17 PM - edited 07-20-2023 03:17 PM
it is no longer Quebec only, it is available to everyone
https://www.publicmobile.ca/en/on/plans
This plan is limited time only, so, join now if you need it. We don't know when will PM pull this away, but once you are in, you are in
