LOST PHONE
06-21-2023
11:41 AM
06-21-2023
06:19 PM
computergeek541
06-21-2023 01:05 PM
06-21-2023 12:56 PM
HI @rob24 Login My Account once more, go to Profile, and check the sim card number, is this still the old one there? or new one?
06-21-2023 12:47 PM
@rob24 wrote:I'm not that new I bought a new Sim card HOW DO YOU GET THE NEW PHONE TO WORK AFTER I EVEN PUT IN THE NEW SIM CARD CODE ON HERE STILL NOTHING WORKS ZERO CUSTOMER SERVICE Idiots are going to Lose Customers over these SIMPLE PROBLEMS.
@rob24 - does your new SIM card number match the SIM card number showing in your My Account?
If yes, then a restart should get services working again. UNLESS, your account is suspended for nonpayment. Then you will need to make a manual payment and reactivate your account.
If your account is active, and you swapped the sim card number correctly on your My Account, then submit a ticket with CSA via methods already provided above.
06-21-2023 12:04 PM
Did you log in to your account and use the change sim function?
06-21-2023 12:04 PM
@rob24 so, you updated your sim card via My Account? did you use a mobile device to do it?
there is a little glitch using mobile device to make sim card change, please use a computer (desktop or laptop) to make the change sim request. You can first go to My account using the computer to confirm if the sim card number shown is the new one, if not, make the change,.
If it is the new one already, then reboot your phone once, try Reset all networks. And if that does not work, your last resource is to open ticket with support:
06-21-2023 12:01 PM
06-21-2023 11:46 AM
06-21-2023 11:44 AM
@rob24 - you have a new SIM card to replace the lost one now? If so, you can log in to My Account and swap the sim card number there.
See "How To Change Your SIM Card" in this Help Article: https://www.publicmobile.ca/en/on/get-help/articles/change-sim-number
Ensure you remove the lost/stolen feature, if you had that on.
If issues with your My Account, click here to request a SIM Swap with the Public Mobile Customer Support Agents (CSA): Submit ticket for a SIM SWAP
Or, if issues with Chatbot, contact Public Mobile Representatives (CSA) by submitting a PRIVATE MESSAGE to start a ticket to them here: Private Message to Public Mobile Customer Support Agents (CSA)
06-21-2023 11:43 AM
remove sim from old phone and install it in new phone...BAM...you're in business again.
