Is this USA
09-16-2024
11:10 PM
09-16-2024
11:41 PM
computergeek541
with this plan does it include using in the US or do you have to buy additional roaming
Plans
09-17-2024 12:54 AM
for best talk-ability, make sure you have a volte enabled cellphone that's on the PM whitelist of volte enabled cellphones. Without this you won't have talk in US using your Public Mobile Canada / US plan. Data and messaging will work fine....it's just volte that's required for talk while in US.
This link will show you the PM whitelist...
09-17-2024 12:30 AM
Here is some more information about US roaming with Public mobile:
https://www.publicmobile.ca/en/ab/get-help/articles/can-us-subscription
https://www.publicmobile.ca/en/ab/get-help/articles/us-roaming-troubleshooting
09-16-2024 11:17 PM
@Cone this plan will work for both countries. Calling, texts, data. There is no need to buy additional roaming.
