Is Motorola G200 working with Public Mobile?
08-27-2022 01:14 PM
08-27-2022 02:23 PM
Yes your Moto G200 is compatible in 3G and 4G.
08-27-2022 01:24 PM - edited 08-27-2022 01:34 PM
these are the bands you phone has, BOLD are the compatible ones
3G bandsHSDPA 850 / 900 / 1700(AWS) / 1900 / 21004G 4G: bands1, 2, 3, 4, 5, 7, 8, 12, 13, 17, 18, 19, 20, 26, 28, 32, 38, 39,
You have enough compatible ones, so, your phone would work here
add:
these are the bands PM uses:
08-27-2022 01:16 PM - edited 08-27-2022 01:16 PM
As long as it can handle PM's frequencies you will be OK.
Public Mobile uses the following frequency bands:
4G LTE and LTE Advanced: 700 MHz, 850 MHz (band 5), 1900 MHz (band 2) and 2100 MHz downlink and 1700 MHz uplink (AWS).
HSPA: 850 MHz, 1900 MHz (UMTS).
https://www.publicmobile.ca/en/on/get-help/articles/check-your-phones-compatibility
