12-03-2019 09:16 AM - edited 01-05-2022 08:17 AM
I switched to public mobile a few months ago and everything is working great. Even successfully used the US Data roaming on a recent trip. I can make and receive phone calls, send and receive text messages, and use my cellular data to access the internet.
The only issue I have is that I am unable to send or receive photos via text messages. I have an iphone SE. Any thoughts on how to resolve this?
Thanks!
12-07-2019 08:18 PM
Hi - I have an iPhone SE too and have received photos via text message with no problem. Have you tried making sure MMS Messaging is turned on (Settings > Messages > MMS Messaging)?
12-03-2019 05:46 PM
@MarilynfanMake sure you have the MMS and SMS options + data turned on
You are not specific but I assume you are having issues with other people using Android phones.
12-03-2019 05:24 PM
is you WiFi off
12-03-2019 04:05 PM
Call Apple support and get your OLD phone number removed from your current iPhone se. That'll fix your problem!!
12-03-2019 11:09 AM
I would try the below Iphone steps provided in another comment.
If this does not work you may need to contact the @moderator for further assistance.
Also try removing your sim card and cleaning with a soft cloth then putting it back int o your phone
12-03-2019 09:46 AM
In your settings section in iMessage section, make sure MMS Messaging is turned on.
12-03-2019 09:21 AM
Try the following steps,
