Invalid email address
Jjbates
I Can not reset password on the account as the email on file is invalid?
@Jjbates   if the email address was wrong, just message CS Agent and request for a change and they can arrange for password reset as well.
Meow
If you provided invalid email while creating self-serving account, you have to contact agent to update your email.
But, even with invalid email and correct password you still can login to self-serving account. Meaning if you provided email like [email protected] you can still use it to login as long as you provide correct password.
@Jjbates  - have you ever created a self serve account before? If not, then register for one here: https://selfserve.publicmobile.ca/self-registration/
Or, if you have created one, did you try the Forgot your password option? here: https://selfserve.publicmobile.ca/forgot-password/
If still issues, contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them:
1 -  Faster  use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 – Slower - Use this link to:
Contact Public Mobile Representatives (CSA) by submitting a message(ticket) to them here:
Private Message to Public Mobile Customer Support Agents (CSA)
edit, forgot to mention...if your account has been in nonpay/suspended status for over 90 days, then you lost your account, phone number and access to self serve.
