04-29-2022 12:50 PM
Hello:
Could you please tell me why I cannot receive calls from other cellphones when my data is turned off. I can receive land line calls. Thanks.
04-29-2022 01:39 PM
thats what the community is for!!
04-29-2022 01:29 PM
Was this in reference to your other post here: https://productioncommunity.publicmobile.ca/t5/Get-Support/Receiving-calls/td-p/817992
Does that mean issue is fixed now?
04-29-2022 01:21 PM
Hello Community;
Thank you all for your quick and helpful replies. It is much appreciated!!
04-29-2022 12:56 PM
If it is just your cell phone line and not 3rd party voip apps you shouldn't have an issue, could be a settings issue even though that seems unlikley as well
04-29-2022 12:54 PM
HI @BugsLady are you sure you are talking about regular phone calls and not those VoIp calls like from Whatsapp, Fackbook Calling, etc? Only those need Mobile Data
can you make outgoing calls when your mobile data is off?
At lesat try to change to 3G Only for your network type and check if you can receive incoming calls
04-29-2022 12:53 PM
@BugsLady - did you just activate a new number or transfer your number over from another provider?
Calls do not require data to be enabled. Are you receiving calls through some online app?
Try:
*turn off your phone, then reboot
*removing your SIM, then reinserting it
*go into airplane mode, then going back to regular mode
*perform a reset network settings on your device
*try your SIM into another compatible phone to see if the same issue persists
