Internet not working
12-02-2018 06:56 PM - edited 01-05-2022 02:40 AM
Hey I just had my phone unlocked but the internet doesn’t work. I’m still able to make calls and text. Anyone know why?
Phones
12-04-2018 05:28 PM
Restart your phone set or try putting phone on airplane mode and then restarting it. If its an iphone, you can find instructions on how to "force restart" it
12-02-2018 07:08 PM
Likely need to adjust APN.
https://apn-settings.com/how-to-configure-apn-settings-android/
12-02-2018 07:01 PM
@Vesnaahtchiev, First off, what phone do you have? Have you checked to make sure your phone is compatible with Public mobile's data network. You can do so at the following web sites.
If it is compatible, have you checked your APN settings?
Is Data enabled on the phone?
12-02-2018 06:59 PM
What plan did you subscribe to ? Could be you've exhausted your data alottment already, depending on which plan you have. See if it works with the wifi if you're in a wifi area.
