Internet is slow indoor
SeoWAKAhahaha
I just joined the Black Friday Deal $34/20GB 5G data yesterday, it works fine in outdoor. However, it doesn't work inside my home. I only have the one bar for signal (or even only have the sos icon on the top right signal area) and can't connect to the internet. Is there any thing I can do increase the the speed? I'm using iPhone 11 and located in Vancouver if that helps.
2 REPLIES 2
@SeoWAKAhahaha  Try putting your phone to LTE when indoors you should get better signal and faster speeds of 100mbs of a 4G plan do speed test to confirm
Speed test
https://www.speedtest.net/apps
HI @SeoWAKAhahaha
did you do a proper speed test and confirm the speed?  sometimes one bar of signal does not mean it is slow
Also on your network mode, change Automatic to 4G, or 5G or 5G On or 5G auto, check each one and see if you get better speed
But keep in mind, do not have too many speed test, each speed test can use up to 500 Mb of data
