No data
10-06-2024
03:12 PM
10-06-2024
03:46 PM
computergeek541
I recently purchased a phone from Amazon the fine print states it supports the networks. I currently have a SIM card from public that is working fine in my s9. When I try to put it into the new phone reset the phone and do it properly I have cellular and messaging service but I do not have any mobile internet on the device through the SIM card all the settings are correct mobile data is turned on I have selected the correct VPN but still nothing as soon as I connect to Wi-Fi it works as if it should I can just not get any data on the SIM card or tried everything I can think of so I thought I would post and see if anybody has an insight
I'm actually returning the product It is so slow and extremely laggy but thank you for your responses
Phones
10-06-2024 04:32 PM
It sounds like the phone is not completely compatible with PM.
If it is a Blackview phone…return it because it is not compatible.
10-06-2024 03:31 PM
I'm actually just going to return it It's slow and laggy. Thanks for the response as far as the uplink and downlink frequency they are bang on to what is posted for the public mobile but the phone is extremely laggy I haven't even installed anything yet but thanks for the response
10-06-2024 03:18 PM
what exact brand/model of the phone?
it could be that the phone is not compatible with PM network and hence the data does not work.
And voice work? try to change the network to 3G only or WCDMA only and data might work
but you might want to give us the exact model of the phone so we can confirm if it is not compatible with PM network
