Internet Access configuration for Dumb phone
dthisner
I just got myself a Nokia 225 4G and I am having issues with accessing internet. Anyone who knows the configurations for a dumb phone?
Apparently I am not able to enter an AccessPoint longer then: http://aliasredirect.net/proxy
Thanks,
Dennis
1 ACCEPTED SOLUTION
Accepted Solutions
dthisner
This worked for me, both internet and MMS. Added reply to: https://productioncommunity.publicmobile.ca/t5/Get-Support/Help-setting-up-MMS-and-Data-on-Nokia-331...
Only thing that does not work for me is when I am trying to do a software update.
NOTE!
The MMS Set Home Page is HTTP, do not use HTTPS! <<--- remove the S
Access Points:
  • Leave TELUS and TELUS MMS alone.
  • Add the following:
    • Name: Public Mobile
    • Username: Empty
    • Password: Empty
    • Access Point: sp.mb.com
    • Gateway: Empty
    • Port: 0
    • Set Home Page: Empty
    • DNS Address: Empty
    • Network Type: HTTP
    • IP Type: IPv4
  • Also add:
    • Name: Public Mobile MMS
    • Username: Empty
    • Password: Empty
    • Gateway: 74.49.0.18
    • Port: 80
    • Set Home Page: http://aliasredirect.net/proxy/mb/mmsc
    • DNS Address: 74.49.0.18
    • IP Type: IPv4
  • Click on Public Mobile to activate it.
  • Then go into System -> Messages -> MMS -> SIM Access Point and set to Public Mobile MMS.
12 REPLIES 12
0PX9O4
@dthisner
If it's a 4G phone then it needs to have APN settings. Here's the thread with the settings that you need to have: https://productioncommunity.publicmobile.ca/t5/Get-Support/How-do-I-set-up-data-APN-on-my-smartphone...
Are you able to find where to set these up on your phone?
0PX9O4
Here's a website with some additional information about the APN settings on that particular phone:
https://www.manual-owner.com/nokia-225-internet-settings.html
dthisner
I am not able to enter: http://aliasredirect.net/proxy/mb/mmsc into my APN settings It is to long
0PX9O4
@dthisner
Oh okay, I understand now. That setting is only necessary for sending MMSes, you should still be able to use internet on the phone without it. Have you entered everything else?
dthisner
it is difficult, since my settings names does not correspond to the one to the first link you sent
I have:
AccessPoint
Gateway
Port
Set Home page
DNS address
Network type
IP type
0PX9O4
Set "sp.mb.com" as the AccessPoint, and leave everything else blank. For Network/IP type, you should have a couple options, what are they?
dthisner
I have one named Telus that has following:
Access Point: sp.telus.com
Gateway: 74.49.0.18
Port: 80
Set Home Page:
DNS: 0.0.0.0
Network type: HTTP
IP Type: IPV4
0PX9O4
All you really need is sp.mb.com as the Access Point Name - have you tried this yet?
The Telus access point will likely not work on Public Mobile, though you're welcome to try it.
The Gateway and Port settings are needed only for MMS, which you can't use anyway because you can't set up the MMSC on your phone.
IP type will have to be IPv4, since PM does not support IPv6 yet. Network type will also have to be HTTP I'm guessing. I can't be for sure because you haven't specified what the available options shown are on your phone. Some phones have a IPv4/IPv6 option for IP Type that is the safest bet.
dthisner
