3 hours ago - last edited 2 hours ago by computergeek541
Does PM do any international roaming data add ones (travelling to Asia) ? I only see add ones for US
3 hours ago
hi @Carol91
Since PM has no roaming service in Asia, you need to buy local data sim card or travel esim
if you want to make and receive calls back home, you can use VoIP app Fongo. Fongo will give you another 10 digits Canadian number, you can use the app to make/receive calls/texts
3 hours ago
As stated, Public Mobile only works in Canada and the US.
Here is an option for you though.
Here is a link to overseas SIM cards that may help.
You can then download an app like TextNow and pick a local number to where you live now and can use it there to call back to Canada free.
3 hours ago
Only US if you have Canada US plan or Yiu buy US add on, there is no roaming in any other countries.
3 hours ago
@Carol91 No sorry USA is only place public mobile has roaming , you best bet is to get local pre paid SIM card in Asia for your trip away
