Intermittent problem making and receiving calls
Mathan
  • I’ve been getting intermittent problem making and receiving calls. When I make a call it says some error number and then the number I called is not in service for many numbers, all of them are perfectly working when I call from another phone. Also, incoming sometimes it’ says the person you have is not taking any calls right now but I do get the call but they don’t hear me.. these problems started just 2 days ago and the problems are intermittent. I tried restarting the phone several times. Removed and reinserted the sim but no luck.
Meow
Most likely you are losing conection to tower or tower is malfuncioing.
Doe this occur at ANY location or one in particular?
@Mathan  Are you putting a 1 in front of the contact , also try reset the network settings
