03-17-2023 05:48 PM
Hi,
FONGO's phone number originated from Fibernetics Corporation: 464D-NSR/1. Is Wireless: no.
I signed up yesterday, and my Samsung phone worked with Fongo's interface using PM's (Telus) sim card. However, after 24 hours, my number is still listed as a landline.
Today, I deleted Fongo's app, and after that, I cannot receive any calls, nor the voicemail box is working. Interestingly, I received voice mail via email, which features I will miss significantly from Fongo's services.
On the same token, I cannot receive security codes via SMS. This was my problem with Fongo's services. I paid for a worldwide SMS service, but their platform's security codes won't work. It used to be worked many years ago.
So, my question is, how long it takes to complete the phone number transfer from Landline to Wireless?
Thank you for your time.
03-17-2023 06:02 PM
Officially FAQ says 3 business days now, but could take longer than that.
You can keep using Fongo in the meantime, when you notice Fongo doesn't work anymore that would mean your number is ported and active on PM. (You should not outright cancel Fongo until the port is completed, btw)
Also, welcome to PM! Hopefully you had a referral to sign up with, if not, members here (like me🙈) would be happy to give you a code! You can apply this code retroactively.
03-17-2023 05:58 PM
hi @Livingstones porting for m VoIP takes a week or 10 business days. Why you uninstall Fongo app so early? Install it back and login until port completed. Not sure if Fongo will send text for port authorization
There is a porting team to call to track status. Will send you the number. Please check your Community inbox
03-17-2023 05:56 PM
Thanks.
03-17-2023 05:51 PM
As far as I understand, voip and landlines can take several days to finish. I hope you haven't taken the rug out from under the process by mucking around with the Fongo side.
03-17-2023 05:51 PM
@Livingstones Can take up to a week to transfer land line to mobile
