10-09-2022
12:15 PM
10-10-2022
12:09 PM
Dunkman
10-09-2022 10:44 PM
New Brunswick.
10-09-2022 10:43 PM
On Android, Messages.
10-09-2022 01:03 PM
Start with a phone reboot
try to go the Message app's App info to clear cache
You might want to also download another Message app, maybe Google Message , and see if you can send text without problem there
10-09-2022 01:02 PM
What province and general area are you located ? There have been reports of localized outages in parts of Ontario earlier this week.
10-09-2022 12:45 PM
Typically it could be an issue with the network. Sometimes toggling between airplane mode on/off works to reset the phone drivers. Alt, it could be a network issue depending on your local. Here is an article on how you can test your network connection. https://www.comparitech.com/net-admin/how-to-network-stability-test/
I hope it helps!
10-09-2022 12:35 PM
@dafou555 - if could be network related, so that it will only send when available to do so.
Are you using Chat Features? This requires a wifi connection or data to send/receive texts. If you are using android and you use Chat Features, then I suggest you turn that off, as it requires wifi or data to send/receive texts.
Disable your Chat Features:
If not a Chat Features issue, restart your phone and perform a reset of the device's network settings. These actions could help finicky texting issues.
10-09-2022 12:17 PM
If everything worked well until now, it could be network hiccups.
Do you use native SMS app or 3rd party app?
