regarding Sim card
Ruhanamanhassss
My sim card is not working.Its locked and require  PUK code. So, from where i can get it.
@Ruhanamanhassss wrote:
Hi, its iphone 13 pro not samsung.
There's no such thing as a network unlocking code or SIM network unlock PUK for any Apple device, so this must be the PUK specific to your SIM card.  Please use the chatbot instructions previously provided to open a ticket to get your SIM card's PUK.
Ruhanamanhassss
@BKNS27 wrote:
@Ruhanamanhassss
Just wondering if you have a Samsung phone?
If you do, you will need to contact Samsung Canada for a PUK to unlock your phone.
If you don’t have a Samsung phone, just contact a CS_Agent for a PUK for the SIM by creating a ticket on SIMon Chatbot or private message them on this Community page.
It's true that Samsung can help with a Samsung device askng for a SIM network unlock PUK, but the concept of needing that code isn't specific only to Samsung.  Any phone that requires a network unlocking code can require the SIM network unlock PUK, something that Public Mobile can't help with unless the phone is locked to Telus (although Public Mobile can help with the Public Mobile SIM card's PUK).
@Ruhanamanhassss
Hi @Ruhanamanhassss
there are different sim unlock PUK.  If yiubreally looking for sim card unlock code you can open ticket with CS Agent
at : https://publicmobile.ca/chatbot
First type Contact CS Agent,
then select the only choice there:  "Contact..",
from the list of ,  choose "Other"
finally click the the blue link about submit a ticket
